To the Point of No Return..
Pan & Tilt - lowest point, has/can be positioned behind 'phasing'. Once released, you can not re-edit as it keeps grabbing the phasing fader
Plus Phasing Fader is not changing in real time, so you adjust and release to see the Increment number.
The X&Y Grid is so slightly off the background white, its impossible to see.
ESAPRO2 - Points
ESAPRO2 - Points
- Points.jpg (30.01 KiB) Viewed 4788 times
Re: ESAPRO2 - Points
First of, I am so sorry for the late response. Most of these issues should be fixed already.
We will be tweaking the colors a little to make the grid more obvious.
Thanks a lot for your feedback.
