Stick DE3 : Scene convert from ESA to ESA2
MIA
Post by MIA » Sun May 06, 2018 6:44 pm
Dear
I use a stick DE3 and programmed all my scenes some years ago with ESA and stored it with the fileformat *.arc
Now i installed ESA2 but this program use different file format *.dlm.
Also i do a firmware update to version 1.17.
When i start the program and connect via ethernet it connects.
But when i click on stand alone and try to read out the stickk i get a failure :
Read memory
Impossible to read memory
So how could i use my scenes with ESA2.
Is it possibel to convert the files ?
Best regards
Karl
Re: Stick DE3 : Scene convert from ESA to ESA2
Post by nick » Fri May 11, 2018 3:09 pm
Hi Mia,
Unfortunately, it's not possible to read .arc files with ESA2. When you press the read memory button in ESA2 it will look for a .dlm file on the SD card. There is not one there so it will show this error message. If you wish to use ESA2 you will have to create a new show from scratch.
If you want to work with the original .arc file you may be able to find this on the SD card and use it with ESA Pro on a PC.
The latest official firmware version for the Stick-DE3 (at the time of writing 11/05/2018) is 1.13.
