Setting Scene Speed Remotely
Posted: Mon Aug 01, 2016 11:18 pm
by riebschlager
I'm trying to use the remote protocol to set a scene's speed and I'm having no luck.
The remote protocol guide says that there are two bytes you pass for the "configured speed value" but I don't know how those values relate to a percentage, or how exactly the unit is using those values internally. Any help?
Also, it seems that changing speed value after starting a scene will throw it into an infinite loop, even though the scene is marked to only play once. Is this avoidable?
Re: Setting Scene Speed Remotely
Posted: Thu Aug 04, 2016 3:38 pm
by nick
Thank you for your message. I have not managed to replicate the infinite loop. Can you describe in more detail?
I believe you're trying to use Quick Triggering commands?
Here is the reference.
https://storage.googleapis.com/nicolaud ... otocol.pdf
As you mentioned it, unfortunately, does not explain how to use the 2 bytes to control speed.
Here is what I have found using Packet Sender :
10 in decimal = 1% on the dimmer.
Example A : Scene A1, Speed 20%.
53 74 69 63 6b 5f 33 41 6D 00 01 00 00 06 00 00 C8 00 00 00 00 00 00 00
Key numbers:
01 = select scene 1, page A
06 = speed command
C8 00 = c8 = 200 in decimal, which = 20% on the dimmer.
Note: You must have the scene selected on the STICK-DE3 to visibly see the change on the LCD display. This is not a change scene command.
But what if you need to set 50% speed? i.e. We send number 500 in hex = 1F4. How do we write this in the hex string?
Example B : Scene A1, Speed 50%.
53 74 69 63 6b 5f 33 41 6D 00 01 00 00 06 00 00 f4 01 00 00 00 00 00 00
Key numbers:
f4 01 = 1f4 = 500 in decimal = 50% speed
Example C: Scene A1, Speed 100%
53 74 69 63 6b 5f 33 41 6D 00 01 00 00 06 00 00 e8 03 00 00 00 00 00 00
Key numbers:
e8 03 = 3e8 = 1000 in decimal = 100% speed
Example D: Scene A1, Speed 200%
53 74 69 63 6b 5f 33 41 6D 00 01 00 00 06 00 00 00 7d 00 00 00 00 00 00
Key numbers:
00 7d = 07d = 2000 in decimal = 200% speed
If you need any more help.
Posted: Fri Aug 05, 2016 4:50 pm
by riebschlager
This is super helpful, thanks Nick!
Posted: Fri Aug 05, 2016 5:35 pm
by riebschlager
To expand on the "infinite loop" I was wrong about that part. Here's what's actually happening.
I have a long strand of lights. I want to "knight rider" a block of 10 lights to one end and back. I need this to happen for specific durations. When I modify the speed of the scene, it speeds up the effect, but it repeats for the total duration of the original scene.
So if I have a 10 second scene and play it at 200%, it doesn't stop at 5 seconds, it plays 2x the speed for the full 10 seconds. Is this more or less unavoidable?
