SD-Card read out
The star of the STICK family.
med
SD-Card read out
Post by med »
Hi
Is there anyone that have tried the following. If the customer send in the SD-card from his Stick-DE3 ( or a copy of it) is it possible to read out the programming from the SD-card reader on the PC and reprogram and save it so it is ready to use in Stick-DE3 panel.
I don't now if the show file is on the card I have not done the programing from the start.
Unfortunately I don't have access to a STICK-DE3 where I am.
Re: SD-Card read out
If the program was made in the last year or 2, the SD card should contain a .arc file which is a backup of the file you can open with ESA Pro
