Stick 3 touch panel disable
Posted: Fri Mar 28, 2014 12:36 pm
by CARLOS
I need to disable touch panel in order to avoid changes in a programmed installation. I donĀ“t find any option. Perhaps in Hardware manager?
Re: Stick 3 touch panel disable
Posted: Thu Apr 03, 2014 6:37 am
by gesatecnico
If you want disable a touch colorwheel, you will enter in the menu-pallet and disable any option.
Posted: Thu Apr 10, 2014 10:14 am
There is a new lock function coming with the next firmware which will be available tomorrow or Monday. This can be enabled from the menu.
Once enabled, the stick will automatically lock after 120 seconds, or can be manually locked by holding the dimmer mode button for 5 seconds. When locked, the screen will show a red square and can be unlocked by holding the dimmer mode button for 5 seconds.
Posted: Fri Sep 19, 2014 2:56 pm
by Lumenpulse
The remote IOS apps do not seem to be able to unlock the controller remotely. Is there a fix for this? the app will not function if the controller is locked.
Posted: Wed Sep 24, 2014 3:28 pm
This is not available at the moment but I'll see if we can add it in the next version
