New STICK-DE3 Official firmware 1.02
Post by simonB » Thu Mar 27, 2014 10:21 am
We have a new official firmware which will be available on our downloads page within the next 2 weeks. This contains the following new features and bug fixes since the June 2013 version:
_______________________________________________________________________________
********FIXED BUGS********
sometime DMX LIGHTPAD display a white screen, we need to exit and re-try
CW WW support
the dimming is not working correctly on areas above area 6
area 7 dims area 1, area 8 dims area 2 etc.....
fades don't work properly on DMX universe 2
Trigger a port
Press an arrow
The screen will stop updating when another port is triggered, however the scene will play
STICK wake on port trigger
-stop or pause a scene by holding the scene button
-change page
-change back to original page
-the top icon says Stop/pause, the middle icon says Play
fading fixed with blackout button
several other small bug fixes and optimisations
********NEW FEATURES********
daylight saving day
default IP address should be 192.168.1.20 when you reset the stick, not 000.000.000.000
possibility to start on the previously running scene
lock with passcode
possibility to dim to 0% in screen settings
Possibility to trigger a calendar event when the controller is on standby
If a scene has a fade, it will fade in when the stick is powered, but it won't fade in when the stick is switched on and off from the standby button
Fade scene ( 5 choices )
Never
From Show
Force
Force max
Force min
in Date/Time settings ADD 3 parameters Longitude/Latitude/UTC-GMT (
Longitude -180 to +180 step 1 Default 0 / Latitude -90 to +90 step 1
Default 51 / UTC-GMT -12 to +13 step1 Default 0 )
The device shows 59 instead of 23 when you press the "-" button if you are on "0"
not possible to set a manual IP address (it fails to save)
possibility to select a scene without activating it
option to synchronise blackout on the network
