Empty SD Card
The star of the STICK family.
CARLOS
Empty SD Card
Post by CARLOS »
STICK 3 serial number 650818 , firmware 1.01.
Shows "Empty SD Card" when power on.
Using Hardware manager via USB port shows "An error occurred while storing settins Error code XHL 44"
Using ESAPRO via USB port when try to write the interface memory shows " Unable to write the memory"
Re: Empty SD Card
This sounds like an SD card problem. Format the SD card in the computer as NTFS or FAT32.
CARLOS
Re: Empty SD Card
Post by CARLOS »
Solved after formatting SD card.
Thanks.
