Using Calendar triggering and sunset/sunrise.
Posted: Thu Apr 11, 2013 11:04 am
Hi there!
I am using DE-3 with firmware 0.99 and ESA Pro BETA (Mar 27 2013).
Problem N1. My case is very simple. Many DMX channels works simultaneously in static mode. Only "ON" and "OFF" in specific time of day. I created 2 scene and it works fine in "Live" mode. But i can't do it auto in "Stand Alone" mode. Of course i use "Assigne all scenes" (by drug and drop from "Area/Scenes" tab to "Stick" tab) and then Menu-button "Write the interface's memory". After that, if i use the touch button on device - scenes switching fine. But when coming programmed time - nothing happened. I tried to use different option in Trigger menu (in calendar page). Can you help my with that?
And next terrible step - configuring sunrise and sunset. I can't setting "area" because i can't find where that setting is. Hardware configuration tool (i guess) till not working properly with DE3.
Thank's in advance!
Thank's in advance!
