Using Calendar triggering and sunset/sunrise.
nuh
Post by nuh » Thu Apr 11, 2013 11:04 am
Hi there!
I am using DE-3 with firmware 0.99 and ESA Pro BETA (Mar 27 2013).
Problem N1. My case is very simple. Many DMX channels works simultaneously in static mode. Only "ON" and "OFF" in specific time of day. I created 2 scene and it works fine in "Live" mode. But i can't do it auto in "Stand Alone" mode. Of course i use "Assigne all scenes" (by drug and drop from "Area/Scenes" tab to "Stick" tab) and then Menu-button "Write the interface's memory". After that, if i use the touch button on device - scenes switching fine. But when coming programmed time - nothing happened. I tried to use different option in Trigger menu (in calendar page). Can you help my with that?
And next terrible step - configuring sunrise and sunset. I can't setting "area" because i can't find where that setting is. Hardware configuration tool (i guess) till not working properly with DE3.
Thank's in advance!
Ben
Re: Using Calendar triggering and sunset/sunrise.
Post by Ben » Wed Apr 22, 2015 4:09 pm
Hi there,
Firstly please can you download and install this beta version of the hardware manager to upgrade your firmware to 1.05. This version of hardware manager is just been finalised and will be openly available next week.
Direct Link:
http://www.nicolaudie.com/downloads/fil ... 5_test.zip
Also please can you download the latest version of ESA Pro (Version Date 11th Feb 2015).
Latest Software can be found here:
http://www.nicolaudie.com/en/download.htm
If you could please update all that then we can have a look at the problems you are having.
Cheers, Ben
