use of pages
jacou
use of pages
Post by jacou » Tue Jan 01, 2013 9:39 pm
what is the function of the pages and how can I use them?
I get the message I may not mix scenes from different areas in one page (still he drops them as if nothing is wrong. A bug? He should ignore these actions I assume?).
I assume a page is strongly related to an area? By switching the page I suppose you can change a scene in different areas without touching the (global) settings of other areas.
Is that correct?
dragging and dropping to page A (default?) fills in the matrix op the pages.
I can switch the screen with the rectangular buttons on the GUI from A to B and so on.
But the problem is that i can not populate these other ages...
I can drag and drop scenes to the stick; but he doesn't fill in the matrix? Nothing happens...
Re: use of pages
Post by simonB » Wed Jan 02, 2013 3:39 pm
One page can contain many scenes. The pages on the DE3 can be changed by tapping the buttons below the screen. You cannot add more than one different area on a page. Pages are useful for splitting up a show or area into more manageable pieces so you don't have a huge list of scenes.By using different areas, you can play multiple scenes simultaneously. More information on areas here:
Regarding the bug, it should not be possible to add different areas onto the same page, try with the latest version
