"Power + DMX" RJ45 Port
VLS
Post by VLS » Thu Dec 20, 2012 4:06 pm
How can i "power" my Stick DE3 with "Power + DMX" port ?
My configuration :
StickDE3 "Power + DMX" port <==========> CT305R module Port IN <=== 12 V Input
===> RGB Strip LED
Is it possible or am i obliged to connect POWER4M module to start my STICK-DE3 ?
thanks,
VLS
Re: "Power + DMX" RJ45 Port
Post by simonB » Fri Dec 21, 2012 10:31 am
Hi, you need to check a couple of things:
-pin configuration
-voltage
The STICK takes 6 volts. If you put 12v, it will eventually overheat after a few hours/days.
More information on the pin configuration can be found in the datasheet here:
http://www.nicolaudie.com/downloads/fil ... asheet.pdf
