Problem Using Stick-GA2
Touch Sensitive Intelligent Control Keypad
Moderators: simonB, nick, florent
LightTool
Post by LightTool »
Dear Nicolaudie Team,
i have problems using the GA2.
First i connect everything and open the Software. Everything was working.
Then i used the hardwaremanager to look for an actual Firmware. The hardwaremanager found a new firmware and installed it.
After that i have a lot of problems.
The display of the stick is flickering. The Firmware in the moment is the 0.92.
The biggest Problem is that the LED are start flashing when i klick on the DMX Option in the Hardwaremanager. When i klick on "off" everything is ok, when i klick on "DMX out" the Stripe starts flashing, no controll of the single Channels is possible.
Do you have a solving for this problem?
Thanks a lot, best regards,
LightTool
Re: Problem Using Stick-GA2
Hi There, I've just reproduced this. We'll get it corrected in a firmware update before the end of the week
LightTool
Post by LightTool »
Perfect Simon,
thanks a lot. Curious for the new Firmwarefile. :-)
LightTool
LightTool
Post by LightTool »
Hi Simon,
i updated the FW from 0.92/2014-01-13 to 0.92/2014-04-10.
The DMX Problem is solved. The LEDs are not flashing anymore. :-)
But the Display of the GA2 is still flickering. Dosen't matter if i power it over USB or with the powersupply.
Do you have an idea what the problem is?
Device Typ: Stick2B
Device Name: Stick2
Serial: 550346
Code: Stick2+
Thx.
Light-Tool
