Problem assigning different fixture modes.
peteknobloch
Post by peteknobloch »
I am having problems with assigning fixture modes in the SETUP screen on the ESA2 product. The fixture I am using is Pulse->Ledbar320. The problem happens when I assign 2 of the Ledbar320 fixtures operating in Mode 4 (26ch mode) and then assign 2 more Ledbar320 fixtures in Mode 3 (14ch mode). I then do a SAVE and exit the ESA2 utility. I then bring up the saved .dlm file and the 3rd Ledbar320 has changed to a MODE4 fixture with the 4th one missing due to not enough free room due to other fixtures that I had defined. This is happening with the Sept 14, 2015 release. I tried including the .dlm file with the post but it seems it isn't allowed. Can you help?
Pete
peteknobloch
Re: Problem assigning different fixture modes.
I was able to temporarily fix my problem by creating a copy of the.ssl2 file called
C:\ESA2\ScanLibrary\Pulse\LEDBAR 320 - Copy.ssl2
I used the original file for the MODE 4 settings and the new copy using MODE 3.
