STICK Remote / Easy Remote on ESA 2
Odyseuss
Post by Odyseuss »
Its bit difficult to get ur MArketing MEssage form the homepage in right way:
first question: is the STICK Remote App and the Easy Remote App the same?
the actual message on ur homepage is: Easy Remote the brand new remote App for Sunlite Suite 2 and Esa 2
So its not depending which interface i have?
i can use it for esxample with a SLESA-U9 or a SLESA-U8 Interface?
or can i use ANY StICK Edition with the new EASY remote app? casue the STICK Remote App if its not the same is only available for the DE3 AND THE KE1 Stick
so in conclusiojn: is there a diffference between stick remote and easy remote and if there is a difference what is the difference? and which hardware i need to use easy remote in ESA2 when i dont have a Stick Controller.
and finally - where to download it.
Thanks for Information.
Re: STICK Remote / Easy Remote on ESA 2
No. The STICK remote app controls the STICK in stand alone. The Easy Remote app controls the lighting software and connects to your PC or Mac
No, as this controls Sunlite Suite 2 and ESA2, not the interface
If you're using SLESA-U9 or U8 with ESA2, you can control ESA2 from the Easy Remote app.
STICK-KE1- STICK Remote
STICK-DE3- DMX Lightpad 3
ESA2 software - Easy Remote
Google play or app store depending on whether you're on Android or iOS
