20th Septembver
20th Septembver
We've just put up a new esa2 with some bug fixes:
______________________________________________________________________________
********NEW FEATURES********
_______________________________________________________________________________
all properties of the scene builder are now saved into the scene when you click 'generate'
crash when assigning a keyboard shortcut which is already assigned to something else
delay on button animation in live
date/time trigger bugs:
-if a trigger is set to 'Once', it doesn't work
-if a trigger happens between 2 specified dates, it works every day
-in some cases it was only possible to add 20 time triggers
if you select a color by clicking in the center of the color wheel in the scene builder, the color was not saved on the step
