ignore pan/tilt limit
dornchristoph
Post by dornchristoph »
I have a question about Sunlite Suite (2), maybe someone can help me here.
If I limit the entire range of motion in the Page Settings patch, then all movements are precisely adjusted to the area.
Also, the Pan / Tilt fader in the Switch editor then regulates to its full 0-255 only in the selected area. Is so desired.
Is there a way for a single switch to ignore this limitation?
So if you want to use a spot to illuminate an area that is outside this range of motion?
Thank you
