Need Help for programming a running light
heelius
Post by heelius »
Hy folks.
I´ve got 4 Cameo PIXBar 450 with all about 16 COB-LED together.
I woul´d like to programm a running light that runs over a color-scene.
For example. The scene puts all the 16 COBs into green. And then after hitting the button Running-Light all COBs turn into black/out except the first one. It stays green. Then the green COB walks through the 16 COBs and starts again at COB one.
It´s no problem to programme a Nightrider, Colorflow etc. but the problem is I have to set fix colors.
But I would like to set the color with my scene...and start the Running-Light as effect over the scene/color.
I hope you know what I mean.
Thank you very much for support.
heelius
suetter
Re: Need Help for programming a running light
Post by suetter »
Hi Heelius,
it's very simple to solve this problem:
- Create your running light (i.e. Night Rider...) with the Color White (RGB 255/255/255)
- Create a button and set it in options to "SUB" -> Substract Value - if you whant the Color to be set to Red just set Green and Blue to 255
Now Activate your Night Rider and the Color Button -> Knight Rider color will be red
For more colors just repeat the second step with the inverted value of the color
heelius
Post by heelius »
Hello suetter.
Thanks, that works.
But now I also have to create a lot of buttons with different colors for the Running Light.
It is the same procedure as creating each running light with a fix color.
And now I have a lot of Buttons for the Color Scenes and the Switches for the Color of the Running Lights.
Maybe I`ll find a way to use the Color Switches also as Color Scenes, with fading...
Thank you.
heelius
