DMX hickups?
N.Webber
DMX hickups?
Post by N.Webber »
Hi, I just recently upgraded to Suite 2 and am busy re constructing some shows.
I had a few old LED movers (Chauvet Qwash260 LED) and some generic Par LEDs connected directly to the interface (BC) and all was working well for the first few hours.
Then it started as if resetting every once in a while. Sometimes it happens after a few seconds of running a scene, or it would happen as soon as the cross fade of the scenes was over and the movers would go to their INIT position.
When this happens, the DMX output window continued to show the correct output levels as if running the scene even though the movers were in their INIT position.
I don't know if this is relevant but I did notice from the beginning that the green LED indicator on the interface is lit very low (compared to the red and orange indicators) and the blinking is not constant but as if randomly and at changing intensity.
Any thoughts?
http://www.boniton.co.il
http://www.bt-12.com Balanced Tilting Sounds Better...
