Stand alone mode and external trigger
eddyedfred
Post by eddyedfred »
Hello...
is it possible to use a Suite2 FC+ hardware with the task described as follows:
I want to save some scenes to the box and use it in stand alone mode. This task is described in the manual. No problem. Now, I want to unplug the device from the computer and recall the scenes remotely. This can be OSC, TCP, UDP... whatever. Is there any possibility to trigger saved scenes remotely? Like using a DMX recorder?
Thanks.
Re: Stand alone mode and external trigger
Hi Eddyfred,
Yes, you can do remote network triggering using our Easy Remote app available in the Android and iOS app stores. Unfortunately this doesn't work over the internet or using a VPN, at the time of writing, because Easy Remote uses broadcast network messages for device discovery. As long as you are on the same network and within the same IP range, it will work.
https://www.nicolaudie.com/smartphone-tablet-apps.htm
If you are more technical, you can also trigger it remotely using TCP/UDP protocol. Here is a guide ...
https://storage.googleapis.com/nicolaud ... otocol.pdf
You can try this using the free software called 'Packet Sender' available on PC and Mac.
https://packetsender.com/
