Pan-Tilt + Mouvement
Post by Saensaid »
Hi, i want to know if it's possible to make position (Pan-Tilt) and put above a mouvement (circle), while maintening position i made.
In short, make a mouvement around position. And maintain this mouvement while changing position.
Superbaloo8
Re: Pan-Tilt + Mouvement
Post by Superbaloo8 »
What is possible is to have a fixed position, engage a mouvement and in the same time change the fixed position, stop the mouvement, and you will be at the new fixed position.
For that, all your fixed position shall be scene, and all your mouvement shall be switch. (the switch is prioritary on a scene)
Then, if you want to have your mouvement following your fixed position, I don't know how to easily deal with it. Except to move the fixed position and the movement by playing with "ADD" Switch on pan/tilt.
  • Interface Economy Class
LightJockey
  • @MixLightEvent (31) France
