How to use palettes with LED par's with 6 colours ?
steen4sun
Post by steen4sun » Fri Apr 22, 2016 9:11 am
sunlite last non beta 20150213, win 8.1
I have bought
http://www.americandj.eu/en/wifly-exr-hexpar.html
I cant figure out a way to create a colour palette with these.
I think there is the same problem with easytime effects.
They are hardcoded to rgbw, amd would love to be able to control rgbwa,uv in the same way
whats your best advice ?
TIA
Steen
peteknobloch
Re: How to use palettes with LED par's with 6 colours ?
Post by peteknobloch » Fri Apr 22, 2016 4:22 pm
I may not be the right person to answer this because I am not sure what you mean by Palettes. But since you indicated that you only have rgbw I thought I might find a rgbwa,uv fixture in the latest release. I only have ESA2 to base my fixture types on but if you select the fixture type called:
"American DJ->ultra hex par3->Mode 3" in the latest releas it has a way to control the basic colors,brightness and UV settings. The UV settings is a separate channel. I don't know if the older release you are using has this type fixture. I had a problem with one of the fixtures I use wasn't supported by the older release but the latest March 31, 2016 did. Hope this helps.
Pete
Superbaloo8
Post by Superbaloo8 » Sat Apr 23, 2016 11:30 am
I don't know which kind of palette you are using, but to have RGBWA-UV working, you need to use "New Palette per fixture type" or "New Palette per fixture".
The generic palette will not work for UV channel.
Sylvain
P.S: Did you check that the .ssl2 is correct ?
  • Interface Economy Class
LightJockey
  • @MixLightEvent (31) France
