I'm using Sunlite Suite2 ver. Sept 11 2015 with hardware mngr 1.2.0-21272 SVN:30533M
While I'm connected via usb cable, the port addressing works correctly. However, when I'm
connected thru the network and the USB is disconnected, the ports and switches
do not work. Can the Suite2-FC control the HE10 ports via the network as well as USB?
Can the HE10 ports be control by the network as well as USB?
- Contact:
Re: Can the HE10 ports be control by the network as well as
I'm not sure to understand everything as I never use the ethernet port (ArtNet) for the moment.
But, for me it make sense that if the Sunlite USB is disconnected, the application Sunlite Suite 2 stop to communicate everywhere (the Sunlite USB is like a licence for Sunlite Suite 2, if connected, everything works with the limitation of your interface, if disconnected, mode demo engaged (interface working, but data sent through DMX/ArtNet).
- Interface Economy Class
- @MixLightEvent (31) France
