Is possible make so that you link fixture back together, whitout have you create a new movemnt for those fixtures.
Is possible somehow to make color stepup function, so you if have activatet color 1 , an then apply stepup, then sunlte will change between color 1 and color 2, and then if you activate color 2, then sunlite cycle between color 2 and color 3 , and then so on.
best regards
lars wollsen
Easytime programming
Re: Easytime programming
Hi Lars,
Hope that helps.
This is not possible once the blocks have been unlinked. You can undo your actions using the 'Undo bar' but all your actions will be undone including unlinking the blocks.Is possible make so that you link fixture back together, whitout have you create a new movemnt for those fixtures.
The only way to do this would be to make seperate Switches or Scenes for each colour change.Is possible somehow to make color stepup function, so you if have activatet color 1 , an then apply stepup, then sunlte will change between color 1 and color 2, and then if you activate color 2, then sunlite cycle between color 2 and color 3 , and then so on.
Hope that helps.
