Easytime programming
Wollsen
Post by Wollsen »
Is possible make so that you link fixture back together, whitout have you create a new movemnt for those fixtures.
Is possible somehow to make color stepup function, so you if have activatet color 1 , an then apply stepup, then sunlte will change between color 1 and color 2, and then if you activate color 2, then sunlite cycle between color 2 and color 3 , and then so on.
best regards
lars wollsen
Ben
Super Forumor
Re: Easytime programming
Post by Ben »
Hi Lars,
This is not possible once the blocks have been unlinked. You can undo your actions using the 'Undo bar' but all your actions will be undone including unlinking the blocks.
The only way to do this would be to make seperate Switches or Scenes for each colour change.
Hope that helps.
Benno
Product Support
