returning to previous state after scene/cycle
smilinjames
Post by smilinjames »
is there a way to initiate a cycle or scene that ends and then the show returns to the state before you initiated the scene/cycle?
Ben
Re: returning to previous state after scene/cycle
Post by Ben »
Yes this is possible, there are a few options you will need to select to make this happen.
  • Create your Cycle.
    Unselect the 'Loop' option using the arrow circle icon at the top of the Cycle window.
    Select the 'Release switch when cycle stop' option in the Cycle tab in 'Button Settings'.
    Play your Cycle, when it finishes it will stop and then revert to what you had playing before you started.
Hope that helps
