returning to previous state after scene/cycle
is there a way to initiate a cycle or scene that ends and then the show returns to the state before you initiated the scene/cycle?
Re: returning to previous state after scene/cycle
Yes this is possible, there are a few options you will need to select to make this happen.
- Create your Cycle.
Unselect the 'Loop' option using the arrow circle icon at the top of the Cycle window.
Select the 'Release switch when cycle stop' option in the Cycle tab in 'Button Settings'.
Play your Cycle, when it finishes it will stop and then revert to what you had playing before you started.
Benno
Product Support
Product Support
