Show request + some specific ADJ/Showtec issues
Moderators: simonB, nick, RichterMC, dylan, florent, Ben
deejayyves
Post by deejayyves » Mon Apr 27, 2015 4:45 pm
I am relatively new to Sunlite Suite 2 and I am having difficulties creating a nice show or some buttons/scenes for some of my fixtures:
- 2 x ADJ Sweeper Beam leds (8 rgb leds)
- 2 x ADJ Dotz tbat system (4 rgb leds)
- 2 x ADJ 16 Freq led strobe
Would someone be so kind to create some nice basic shows for this set up ? I could then use these as a basis/example and create some other ones myself.
My particular problems are: I am unable to select "easytime" for these fixtures (only easystep).
Can the rgbs be selected as a RECT ? Anyone any suggestions for a show ?
For the ADJ 16 Freq strobe: in 1 channel mode, you only have the buit-in shows, but no dimmer/shutter. So if I want to use the 1 ch mode, I am unable to use the basic "strobe" function (all 16 lights on-off). In other modes, you have a dimmer/shutter, but no ption to select the built in shows. Any solutions or suggestions here?
I also have 4 x Showtec Indigo Beam MKII: after creating a page, and when I select the pan/tilt function for all 4 fixtures, only fixtures 2, 3 & 4 actually follow the pan/tilt moves. Fixture 1 does not respond. When I select fixture 1 individually, it does follow the pan/tilt movements. What could be the problem/solution here?
Many thanks in advance for your help and advice!
Best,
DJ Yves
