Automatic compressed button release
Oclaus
Post by Oclaus »
Hi there,
I have created some fixed color switches and compressed them into one button field. Unfortunately the switches do not switch the other switches off when I switch in between them.
I have previously programmed other button fields and the automatic release worked nicely. (This was done with a previous Sunlite -Version) . All options whitin the respective switches are the same as within the ones this works.
Propably I am overseeing a detail or is there an issue with the actual version (My version is July 2013). I am really wondering as this is working within other fields...
It would be great if you could come back to me with a feeback on this.
Kind regards,
Oliver
http://www.jmarquardt.com/
http://rote-sonne.com
Sunlite Suite 2 FC
Sunlite STICK
Sunlite SL512EC
APC 40
BCR 2000
mtregael
Super Forumor
Re: Automatic compressed button release
Post by mtregael »
Hi Oclaus,
You should try to update your version first.
Last stable version:
http://www.nicolaudie.com/downloads/fil ... suite2.exe (sept 23 , 2014)
Last beta version:
http://www.nicolaudie.com/downloads/fil ... e2beta.exe (nov 14, 2014)
The new versions can be installed in another directory, so you can keep your old one if a major problem occurs.
To test, export your show from your actual version and import it in the new one.
Let us now if the problem is still here...
Gaël
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
