EasyTime Effects on Custom Fixture Library Broken
beliy333
Post by beliy333 »
I have a Chinese moving head which I made a ScanLibrary file for. When I try to make any easytime pan/tilt effect, it automatically uses other channels like color wheel, dimmer, strobe... I only drop the easytime effect on the pan, pan fine, tilt, and tilt fine channels but when I play the easytime pan/tilt effect it uses the other channels. Any ideas what this could be caused by?
Thanks!
Yan
mtregael
Super Forumor
Re: EasyTime Effects on Custom Fixture Library Broken
Post by mtregael »
Some ideas:
- A wrong Library ? can you tel us the model of your moving head and post de ssl file you use ?
- The moving head may have différent "mode"... 8 channels, 15 channels, 18 channels... and you don't use the good one. Look at the user manual and use the same library profil as the mode selected.
- Bad dmx address ?
Gael
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
beliy333
Post by beliy333 »
I fixed it. I had to reinstall Sunlite Suite so it seems there is some bug but its working now :)
