Sunlite Suite 2 Official 7th April 2014
We have a new official Suite 2 version available here:
http://www.nicolaudie.com/downloads/fil ... suite2.exe
Here are the changes since the previous official:
______________________________________________________________________________
********FIXED BUGS********
_______________________________________________________________________________
problems corrected when rotating a fixture being used in a group rect
default text of text components on the console not displayed
crash when opening XY window on the page settings-> patch tab
if you manually added a Suite2-BC it was possible to choose 'Output 2' from the list, however it's not possible to set 2 outputs with the BC
crash after assigning shutter open/close to followspot
Bug with console control of pan/tilt channels
Suite 2 was closing after deleting a fixture
console->'selected page' option didn't work when pairing a pan command
sometimes default text written in the console designer was not sent to the Easy Remote app
when you load an Easy Show file which has been moved between 2 computers, it now searches the multimedia folder before asking the user to locate the file
if a background file is stored in the show folder instead of the console folder (for consoles embedded in the showfile), it was not sent to the tablet
console->background selection bug
print button didn't work in patch -> print preview window
sometimes the toggle (flash) property was getting inverted
new artnet library supporting unicast
not possible to add buttons to a group component in the CCD designer
inverted channels were not taken into account when designing a standard palette per fixture
not possible to create a pan/tilt effect across a multi pan/tilt fixture
********NEW FEATURES********
easyshow->if a show is already open and another 'load show' command is sent for the same showfile, it will no longer try to reload the same show
multiselection in fixture positioning wizard window by holding shift and dragging a box selection
Joystick support on all console components
New 'Hardware Manager' application for managing DMX controllers
