Pan Speed and Tilt speed fields in Scanlibrary
pperpot
Post by pperpot »
Dear support team,
I would like to know how to set correctly the "pan speed" and "tilt speed" fields in Scanlibrary.
Some of my fixtures are moving faster than the others. I suppose i need to modify theses fields in my fixtures profiles but :
1°) What does "pan speed" represent exactly ? How do i measure it ? Is it the time needed to go from 0 degree to 540 degree ? (same question with "tilt speed")
2°) Do i need to consider my slowest fixture as my reference and set the others fixture profile according to it ?
Thank you in advance for your support
Olivier
Re: Pan Speed and Tilt speed fields in Scanlibrary
Yes, also check for any speed channel types or presets as this will also affect the speed
The fixtures can move instantly if the value is set to 0, so the reference is 0.
pperpot
Post by pperpot »
Thank you for your support
simonB wrote:Yes, also check for any speed channel types or presets as this will also affect the speed
So, if I understand correctly, I need to measure the time the fixture need to go from 0 degree to 540 degree with a chronometer in order to set the pan speed value.
Then I need to repeat this process to measure the tilt speed from 0 to 270 degree. (I also need to check where is the chronometer in my Iphone ;-))
1) Is this correct ?
2) Could you give me an example of a channel that modify the pan/tilt speed ? I have no idea of what I have to check apart from pan/tilt channels.
simonB wrote:The fixtures can move instantly if the value is set to 0, so the reference is 0.
3) What happens if i set a greater value than the one really needed by the fixture ? Does it slow down the fixture movement ?
4) Are theses fields values used only for the 3D visualizer or are they also use for another purpose ?
Thank you in advance,
Olivier
