magic 3d with jands vista2
lebowski971
Post by lebowski971 »
Hi there, I own a sunlite suite2-FC and i'm trying to work with magic 3d easy view controlled by jands vista2 software as a controller but the two software don't comunicate by artnet. I don't know if i'm doing something wrong in the artnet connections or it's impossible to work magic 3d with jands vista2. thanks everybody for an answer!
Re: magic 3d with jands vista2
Hi There, normally this should work fine
-Be sure you have no other DMX software open, just EasyView
-Check that the artnet universes are set up correctly in the Universes window of EasyView
-Check that the IP address settings are correct on your computers ethernet card
