Audio Triggering
allon
Audio Triggering
Post by allon »
I am trying to control 6 dimmer by making them flashing on audio triggering.
For that I followed both tutorials :
Sunlite Suite 2 Tutorials - Sound to Light Triggering on youtube and
I get the audio analyser working well. I get the bmp flashing green.
I edit the dimmer and get my 6 dimmers set to two different easysteps steps. I set the light of these steps differently.
When I press the easystep start/stop button it flashes every 1s (hold time), but when I press the "play with the bpm" or the "play with the music pulse" button, it does not react to the bpm (I thought it would change steps when the pulse green light flashes in adio analyser).
I then thought I had to drag the fixures into the easytime windows (following the online manual explanation) and setting the configuration to "enable music tempo synchronisation", but that does not work either.
Is the problem that I am working by editing the dimmer?
Do you see what I a doing wrong?
Thanks a lot in advance for your answer,
Emmanuel
Re: Audio Triggering
Hi, send over your show file and I'll take a look.
