Got issues with Pan/Tilt Console command
mikachu
Post by mikachu »
Hi everybody,
Havn't posted here for years and, as I discover the new console mapping, I got a little problem that might be a bug.
I own a midicon from Elation and I'm trying to map the Pan/Tilt Live command to the rotary encoders. Let's explain thru a short example.
- Got a show with 3 kind of moving head. (4 of each so 12 fixtures)
- On my desk, I want to select the third movinghead of each page via the same button ("3" button on the right top of the midicon). So I configured this switch in // Select Button , On active page, button name "XY3". It works great (edit : it selects the third fixture on the active page) (edit2 : I renamed each fixture select switch with the same name so that it can work)
- I now want to do the same with Pan and Tilt Control and that's where it doesn't work.
If I specify for the rotary controller //General/pancontrol command/Page MArtin Mac 2000 / Selected button, It works. Then if I tick the SelectedPage option so that this can work on any page, it doesn't any more.
Another issue with the Tilt command. When I try to select this menu, no window opens.
Thanks folks for helping me.
Re: Got issues with Pan/Tilt Console command
Hi, I've just tested and reproduced the bug. We'll correct it in the next version.
mikachu
Post by mikachu »
Did you mean these are both bugs?
Yes both should be corrected in the next beta available in a couple of weeks
