Flash function on a console
Wollsen
Post by Wollsen »
I have a bcf2000 where I have programmed the physical button to work like a trigger button, pushed it is on and released it is off, so that it can work like a flash button, the linked to sunlite 2 activation on a button, and works fine, the problem that is when you have others button activated for the same effect, they are also released when I released my trigger button on the bcf2000, Its like sunlite 2 does not know that you are trying to flash from midi.
I made a short video
https://www.youtube.com/watch?v=qhcKrLOWIFE
Re: Flash function on a console
right click the appropriate button on the console
double click on the command
check 'flash mode' at the bottom
Wollsen
Post by Wollsen »
Thanks for the help.
It working fine know
