Suite2 Official Release 1st July
Moderators: simonB, nick, RichterMC, dylan, florent, Ben
Post by simonB » Tue Jul 09, 2013 10:59 am
This was formerly a beta, here's the changelog since December:
_______________________________________________________________________________
********FIXED BUGS********
If you make a manual mapping or edit inside the console preset window, this is not saved until the software is closed, so if Suite2 crashes, you lose all your edits
showfiles are not being written to SD card
problem with midicon wheel
DMX in wasn't working with the console
- problems with batch delete fixed (check boxen sometimes disappear, batch delete could crash Suite 2 under some circumstances)
- double clicking in standalone editor "pages" could crash software -> fixed
- pre programed switch "cycle movement" was more like a sausage -> fixed
- some problems with reading/writing from/to standalone memory fixed
-there was a huge delay when closing the stand alone window which has been fixed
crash fixed when writing stand alone to DE3
When you control+right click and drag a button, you have the following message:
'Do you want to move the button …. or copy the content of …. inside ….'
Sometimes the options were Yes, No, Cancel and sometimes the options are Move, Duplicate, Cancel
Also, the French version was also not in French
Console designer bugs:
-default component size was wrong after adding a custom component
-'save as' name dialog said Annuler instead of cancel
-possibility to have no image for a component background or button/off
-objects were resized when you made a right side alignment
-wasn't possible to create a +/- button, but possible to edit
-'do you want to save?' prompt missing when closing the designer
-if you canceled adding a component, it still added an empty component
-The list was not sorted alphabetically by default when choosing a component
-When choosing a component, if you sorted it alphabetically, it put the upper case first and then sorted the lower case after
-text was scrolling even through the component size was larger than the text
-it took too long to align text in a good position
console
-Load a console into suite 2
-change the names of some buttons
-remove the console
-create a new console
-the old names were kept instead of using the default names of the new console
console builder: if you make a multi-selection, it was not possible to change parameters unless they were originally the same
console builder: if you change the height of a component so it's higher than the canvas size, it was not possible to select it
stand alone window: interface name didn't change on the interface tab when renamed
bugs with the chaser effect on 'random' and 'random flash' options
-'size' property didn't always work properly
-the effect was not long enough, so it didn't always look random
console page component fixed
page setup wizard->if you uncheck 'add page to master page' , the page was still added
page settings->patch->pan tilt settings
when the grid zoom was set to 150%, wasn't possible to move or resize the area
automatically generated color effects were only applied to the first beam of a multibeam fixture
show MIDI range in info column of console settings instead of 0-255
Change 'USB STICK' text to 'STICK' because you can access it over Ethernet now
color manager->time. When a fade or hold time multi-selection is made, all times are still changed
the page window was scrolling to the top when DMX was enabled for a page
if a channel assigned to a palette was changed to an easy step channel, the channel was displayed as 'EasyStep with palette', however the palette information was not copied correctly
color manager->selected step wasn't applied to the selected steps, only 1 step
It wasn't possible to remove an icon from a button
The button name is now displayed in a compressed button icon when there is no icon
a few missing translations corrected
If you have a lot of buttons compressed as external list and this list was bigger then the screen height, it wasn't possible to scroll or make the list wider
button phasing didn't work on certain channel types (e.g. gobo, color)
when you recorded a cycle in list mode, it said 'after end' even though the elements were not after the end
page settings->patch->Insert a chosen scanlibrary fixture
If you made a multiselection and drag, it was sometimes possible to drag some fixtures on top of others
cycle timeline zoom level wasn't saved
bug when changing an easytime block length to 0.50 as blocks must be in the range of 0.04s
********NEW FEATURES********
possibility to change resolution of pan/tilt grid with arrows
use the new Suite2-FC over ethernet
It's now possible to add components starting with the the 'ER' without special operations being carried out (which were being used in the early testing stages of EasyRemote).
stand alone:
-changed 'Hardware' text to 'Stand-Alone Shows' to make it more clear that each interface is a separate show and not several universes of 1 show
-added the splash screen before writing memory
New view options in the DMX output window
console designer
-changed 'Bitmap' button text to 'Image'
-If you insert an image lager than the canvas, it is now resized to the size of the canvas
now possible remove the columns from the cycle window (list view)
now possible to make a relative pan/tilt adjustment of all selected fixtures in palette editor by holding ctl (like in the page XY grid)
now possible to change the order of palette tabs
color manager->total time is displayed so you know how long to make the block afterwards
auto scroll in fixture positioning window when highlighting and moving fixtures
if a fixture has no dimmer channel, page dimmer is now enabled on RGB channels when the page is generated
support for the STICK-DE3
control and write to STICK-KE1/KU1/DE3 over ethernet
network synchronization of several STICKs
fixture positioning wizard tooltip now shows universe number aswell as address
New console designer including:
Compatibility with EasyRemote app for iOS and Android devices
Default fader, button and dial icons built dynamically
PNG image support
XY grids and Color wheels
A custom component designer (.ccd)
Easier workflow for creating consoles including multi-selection and copy/paste
Manual patching now shown when a patch is printed
In DMX level window, add the possibility to have both dmx value and beam state
Button in palette editor to "show light beam", "solo" and "select all fixtures inside the current palette".
Fixture selection shortcuts in palette editor
New property added to a cycle to, release all switches called after it's been stopped
Cycles now deactivate all switches which have been activated in the Cycle. Some customers prefer the old way of working. Can we add the option to leave the elements and put this in the cycle settings?
