I tested my new sunlite suite 2 (first class) with 3 power rack : show tec D.Pack 6 MKII
Before i used the sunlite suite (EC). I never have problems.
Now when i edit a button (scene, or switch) when i record my modification, the 3 racks are in default (all output of the racks are set to 0 ), and need to be reset.
This is only when i quit the edit page of a button.????
I put a DMX splitter bettween the interface and rack, the problem is the same.
I tested with the old sunlite, it's ok
I tested the interface (sunlite suite 2) with a little dimmer4 (Mac Mah) i don't have this poblem.
Can you help me ?
Thanks, and sorry for my bad english.
David
Big problem using sunlite suite2 with showtec rack
Re: Big problem using sunlite suite2 with showtec rack
Hi David
Try the Suite 2 interface with the Suite 1 software. Do you still have the same problem? If yes, change the DMX timings by opening Tools.exe found in the sunlite suite 2 software directory. Try the enhanced compatibility preset.
thank you for your repply
i tested this solution (Try the enhanced compatibility preset)
you can show my oder post, because the problem si not only on the rack, oder projector flash a short time.
this is only when i modifie a scene or switch.
you can see the defaut on this vidéo
http://www.tugler.fr/SUNLITE/
thanks
(i can't test the sunlite2 interface with the sunlite1 software before next week)
thanks
