I found a bug or I am missing something.
When I make simple effect with easy time like a chaser. It looks like it's out of synq. The red line that runs over the chase is not straight from bottom to the top. When i drag it over the chase it does this in sync, it becomes a straight line and solves the weird sync difference.
Is it possible to solve this (a setting perhaps)? Because now my chase isn't in time with the BPM and it then looks like it has 9 steps in stead of 8.
Easytime Synq play
Re: Easytime Synq play
Do your blocks start and end at the same time? Send me your show and I'll take a look
Thanks for your reaction, but it looked like it was a bug. I've made a new switch with the same settings and it worked fine. When it happens again I will let you know. Maybe I can tell why en when it happens.
