Master fade time for switches
MarLei
Post by MarLei »
i would ask if there is any opinion for a master fade time for switches?
What will i do exactly:
- I usually work with switches in live operation
- So i have for example one switch for a pan-move for moving heads and another for a circle move
- If i turn from one switch to the other i only know the manual fade times in the single switches to make the change smoother
- I think it would be good if there would be an further option in the switch-fade-time-settings to give them a master fade time for fade in/out.
Thanks and best regards,
Markus
Re: Master fade time for switches
Hi Markus
I am not sure of your question. You would like to set 1 fade time which applies to all switches?
markusbrodbeck
Post by markusbrodbeck »
Hello, i think i have the same question.
I wnat to have the posibility to give my switches for pan til positions (down in the middel, up as an cross ...) a adjustable fade time with a fader on my midi/dmx consol.
I think it works with the Fade tab in the Page but i can´t link ist to a consol i only adjust it with the mouse.
I think that was really usefull for live situations you can change the speed of the pan tilt change between two pantilt positions.
Is there any posibility.
Thanks Markus B.
