Easy Statik Sence
Gerd
Easy Statik Sence
Post by Gerd »
hello
I need helb to programm an easy Lamp on
In Detail
I have a Bar the Ambient light will be cotrollt by Stick 3 and ESA Pro,
how can I set an easy light on without a time line and more than one sence per aera ?
Ich don´t like a cue for 24H are there any other way ?
Re: Easy Statik Sence
Thank you for your question.
I understand that you want the light to simply turn on and stay on. You do not need create a show which is 24 hours long because scenes by default are set to 'always loop'. This means they will repeat over and over, forever, until another scene is triggered. You only need a very short static scene on the timeline to make a light turn on and stay on.
If you would then like to turn the light off, you can either create an off scene yourself or enable the default off scene on the Stick-DE3.
1) Press the standby button for 2 seconds.
2) Scene (S) > S0 (off) ... enable
3) Using the scene buttons you will now find you can select A00 which is off.
