16-bit dimming
69morpho
16-bit dimming
Post by 69morpho »
Hi there,
I'd like to start using 16-bit dimming to control simple RGB LED-strips in order to achieve smoother fades especially in low brightness region.
I assume that should be possible in ESA PRO with the right fixture profile. I found profile "rgb16bits" in the "_varied" ScanLibrary folder.
Could you please let me know if this is the right approach for using 16-bit dimming with ESA PRO?
I found the following 16-bit encoder: http://www.led12345.com/16-bit-dmx-cv-d ... p-110.html
Any other recommendations?
Thank you for your help in advance!
Erwin
jbaker
Re: 16-bit dimming
Post by jbaker »
Is your question whether the software can control 16-bit or whether the device you linked can? The software can and you can use a stock profile that is 16-bit or make your own in ScanLibrary.
