A very simple question
Adam
Post by Adam »
I have a set of 8 DMX controlled relays each one of which turns power on to 8 individual circuits each circuit powers various DMX fixtures. I want to power on the appropriate relay(s)(DMX Value 255) and also control the fixtures with a different DMX value so I can Dim the fixture or colour mix it. When I try to add the fixtures to a scene which already has the circuit relay set I get a message saying "You can not set different areas on the same page".
How do I work around this?
Ben
Re: A very simple question
Post by Ben »
Hi Adam,
The problem might be in the fact that you cannot put scenes from different areas on the same page.
To enable for me understand the problem a bit more and to help would you be able to send me the .arc file over so I can take a look?
If you could include names of the scenes so I know exactly what to look for that would be great.
Thanks,
Ben
