Can ESA Pro do performance capture
BackAche
Post by BackAche »
I've been ask to look at a programming a Son et lumière show that is a combination of dmx controlled mp3, dancing fountain and rgb led
The current solution is programmed using ESA pro (which is new to me), what for me would be the best way to program it would be to 'busk' the performance live and capture it and then tidy the resulting cue afterwards
Can ESA Pro do that?
BackAche
Re: Can ESA Pro do performance capture
Post by BackAche »
Unfortunately the job was two-days ago now and so I had to turn it down :-(
For this, you would need to use Sunlite Suite 2. You can create scenes/switches for your different effects and then use a cycle to record a list of button presses
