LED strip RGB-WW-CW
lolocaledo
LED strip RGB-WW-CW
Post by lolocaledo »
I'd like to use LED strip with 5 wires (1R, 1G, 1B, 1 warm white and 1 cool white).
Is there a fixture in ESA PRO with 5 dimmer channel ?
Thank you for your help
Re: LED strip RGB-WW-CW
Hi, the best would be to make one yourself.
-Open scan library
-Drag and drop the RGB channel type
-Drag and drop 2 of the Amber/White channel types
-Right click the amber/white channel types and click properties. Here you can set your warm and cool white
-Click the picture of the moving head in the top left to set other fixture settings
-Close and save the profile within the ScanLibrary folder, it should then appear in the fixture list
lolocaledo
Dear Simon,
Thank you very much.
It seems to be ok.
