Esa Pro
indulgence
Esa Pro
Post by indulgence »
I am having an issue when using ESA Pro, i am sure the solution is obvious but it has been holding me up for a while.
When adding a 5 channel fixture i am only being offered control of one channel.
For example;
Channel 1 = Shutter or lamp on/off
Channel 2 = Dimmer
Channel 3 = Color
Channel 4 = Twinkle
Channel 5 = Color Speed
To enable color selection this fixture requires a signal to mutiple channels, when i create a scene the timeline only gives me control of channel 2 (dimmer) this gives me no function at all as i can't even turn the lamp on.
I am sure i am missing something obvious here but would be greatful of some guidance.
Re: Esa Pro
Right click towards the left of the timeline and a pop-up box will appear allowing you to select which channels to have visible :)
