pesonality file error or software bug?
BertVanRemoortel
Post by BertVanRemoortel » Wed Mar 10, 2010 10:32 am
this is the first time I'm using the ESApro software to program some moving heads.
I'm using the Robe colorspot 170 AT. The moment I show the control channel and add a STATIC to it at the timeline, the program freezes. I found a workaround; show the control channel and then right-click in the timeline to show the presets. When I double click now, the program stays active.
Second problem I'm having: a soon as I want to add some focus information, the pan/tilt values are reset to 0.
Could this be a personality file issue or is it a software bug? Please help.
Regards, Bert.
Re: pesonality file error or software bug?
Post by simonB » Wed Mar 10, 2010 11:15 am
Hello
I can't re-produce your bug whereby the software crashes when a static effect is dragged onto the control channel. Are you using the latest software ver? (dec16). Is it the colorspot 170 AT mode 2 you are using?
Regarding the second bug, yes I see that when effects are edited the X/Y channels are reset. I will speak to the developers regarding this.
michielbr
Post by michielbr » Tue Mar 22, 2011 3:14 pm
I ran in to the second problem (with the pan/tilt values reseting to 0 while editting a gobo or the focus) today while programming a Highend Cyberlight. And as it is going to be used for gobo projection focussing is quit crucial.
Is there a solution or workaround for this problem yet?
Hopefully it will before next thursday as it should be running then.
Michiel Brongers
More Stage Services
Post by simonB » Tue Apr 26, 2011 1:15 pm
This should be fixed int he next release due in a week or 2. Watch the website for the new link.
