RGBA Mixing
Posted: Tue Mar 02, 2010 4:33 pm
Hi there,
I am currently working with some RGB+Amber LED lights using ESA PRO and the STICK interface. The program seems to be able to mix RGB+W internally but I can't see any setting for RGB+A even though i've selected the generic RGBA fixture.
The question is! Is there anyway of mixing RGBA natively in ESA PRO or do I need to work out the levels externally.... and...... if working out externally, any idea where i'd find something to convert from RGB to RGBA? I've had a look and can't find a thing
Any help much appreciated
Colin
Colin
