How to edit multiple fixtures at one time
teggers
Post by teggers » Thu Apr 14, 2005 8:44 pm
I need to adjust the maximum tilt angle (or color - or gobo) of the pre-generated chases. How do I edit (choose/select) multiple fixtures (20 at a time) so I can do a mass edit?
Which window is easiest? The easy show editor or the channel editor?
You showed it to me at the NAMM show, so I know it is in there!
I could not find this in the manual. I think I stumbled across this once - something like "control + a" or something...
Tim Eggers
Guest
Post by Guest » Fri Apr 15, 2005 8:38 am
This is not a question regarding Easy Show software...to edit multiple fixtures, you must use the SHIFT key and move the faders...
