Easy Show problem with MPG file
blaide
Post by blaide »
last year I briefly played with Easyshow on the June 2012 Beta by loading an mpg file and throwing some fixture switches on the timeline and it worked. Now I'm using the same exact mpg file on another laptop running the June 2013 version of Sunlite suite 2 and it won't play the file. When I hit play it shows 0m00s04 on the shuttle control window right above the shuttle controls. The mpg file is 2 minutes and 35 seconds long. If I click on the infos tab, it shows the right time, just can't play the file. Anyone know what's going on?
blaide
Re: Easy Show problem with MPG file
Post by blaide »
Nevermind, found a little tick box called "Enable Timeline" in the video box on the timeline.
