Transitioning between shows
finer500
Post by finer500 » Sat Jun 04, 2011 5:21 pm
I am designing a lightshow synced with music through easy show and I'm looking for a way to transition between shows in easy show similar to the way a DJ would you a cross fade to transition between tracks. As of now, when I transition between each show (song), I have a second or two long gap of silence. Anyway to avoid this?
Thank you,
Oliver
Re: Transitioning between shows
Post by simonB » Mon Jun 06, 2011 6:46 pm
Hi Oliver
There is no way to do this with easy show. Are you playing the music inside easyshow? If not, I would use cycles and link them with MIDI time code.
